Schneider M241 and HMI magelis communication problem
rgua
Mar 2003
144
I have an M241 connected in Ethernet to a HMIS5T panel and I can't get them to communicate
I'm using Machine Expert 1.2
On the controller the Ethernet port has a fixed IP and shows that it has the Machine Expert protocol active.
The panel's Ethernet port has a fixed IP
In Vijeo Somachinenetwork01 it has three objects:
SOM_HMIS5T
SOM_MyController with the node name of the CPU
SomachineEquipment01 with the node name of the CPU
Compiling and downloading are done without errors
Hello, I am making a simple temperature measurement so I can configure my PLC and HMI together. I want the value measured by the sensor connected...
3,689
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
111
Hello, Recently I was asked to analyze the logic of the air conditioning system in one of our departments. The PLC that controls this system is...
154
I have a machine that has M241 PLC. I need to add a couple of outputs to the program, and I don't have the original code. Am I screwed or can I...
472
Hello everyone! I have a Schneider M241 as master of a CAN network with several encoders and whatnot, everything is working fairly well. Now...
1,718
