make a profibus network with plcsim
tomkens
Dec 2003
manchester
21
dear friend
I have several question about plcsim. please help
how can we use it to check analog signals?
can we check a profibus network with it?how?(it is so important please introduce some resorces)
does it support integrated function moudle?
does it work with a real plc(as a master or slave)to make a profibus net?
can we run two virtual plc(with plcsim) in a cp or several pcs(in a network) to make a profibus net?
if you know any useful to add them it will be appreciated?
thank you
Hello tomkens;
i suggest you download the S7-PLCSIM manual from the Siemens website (www4.ad.siemens.de), click on Product support, then search for 1139071 (the ID number for the manual). It addresses most of your questions:
-you can access analog data directly through registers, or through the slider control built-in PLCSIM;
-once yoiu download a Hardware configuration that includes Profibus slaves, the slaves are seen as internal IO addresses of the CPU, so you access these as regular IO modules;
-PLCSIM does not support FMs, integrated or not;
-PLCSIM simulates a CPU; by itself, it does not communicate over Profibus. If you want these features, you must look to Siemens SoftPLC: WinAC/WinLC. These packages use PLCSIM as a front-end, and hardware or software CPUs that can access Profibus IO through a CP5611/5613 card.
Hope this helps,
Daniel Chartier
Hi, I have a doubt about the system architecture shows below: could two master devices install in same profibus network?
2,648
My Siemens Step 7 education progressed today. I'm getting more familiar with how it all works, but at the end of the day I got stuck trying to...
1,021
Hi, I'm retrofitting an Anybus-X Gateway as a Profibus Master on an existing Profibus segment. I'm wondering if this needs to be the last device...
1,217
Dear Superiors,📚:wizard: I'm new for s7-300 and yaskawa v1000 drives communication via profibus. My aim is to find how to run the drive or...
1,774
Good day, I have a problem regarding the configuration and commissioning of a profibus network where the master will be an S7-1500 PLC and several...
1,802
