managed switches
The newer switches from Siemens aren't nearly as expensive as the older lines used to be, and much easier to use. Take a look at the Scalance XB208.
https://mall.industry.siemens.com/mall/en/us/Catalog/Products/10261624
However, when you're talking about any of the industrial rated brands (like N-Tron and Siemens mentioned so far), you won't get anywhere near the price you'll see for cheap office desk grade stuff (probably at least 10-20x more expensive).
Need to operate below freezing, or above 100 degrees? The one you linked won't do. Want 24V supply or something that mounts to a cabinet? Not TP-link.
Need something for a test stand on your desk? The switch you linked will probably do just fine.
Believe me I fully endorse the "you get what you pay for" rule.
Luckily the environment this will be installed is climate controlled and I think it will probably do ok. If not it was only $30, and like you said, it will probably work fine for a desk model.
Do wish they made it DIN mount though, how dare they!
I have used a bunch of Stride (Automation Direct) unmanaged switches and had zero problems.
I have also used one of these where I needed to do port mirroring and it worked well:
https://www.newegg.com/Product/Product.aspx?Item=0XK-000W-00080
I've used Stride unmanaged as well as managed and both work exceptionally well. I use a managed switch if I have remote I/O so I can keep the RIO off the plant network while allowing the processor and HMI access.
Looking into using a Stride Managed network switch in an upcoming build versus a Stratix 5700. Just looking for others experiences, comments or...
4,991
Hi Team, I am looking at spec'ing an Advantech Industrial Managed Ethernet Switch in the design of our OEM equipment to talk EtherNetIP to the...
1,684
We had recently started using Ethernet networks on some smaller machines. Mostly just a PLC, HMI, Laptop Port. As we had begun moving to small...
5,813
I see many references to using managed switches in lieu of unmanaged switches and hubs. My question is, what settings in particular are you...
3,359
Unmanaged Ethernet Switch We recently launched a new Ethernet switch that can be mounted outside the panel. Saves me time and room on the DIN...
5,481
