Maple HMC3102-A and Modbus
sparkie
Nov 2014
KS
1,148
So I'm using this combo HMI/PLC from maple. So far, I really like the interface, but I'm having a problem trying to get something set up. I have around 20ish PID controllers on an RS-485 network. When not in use, the controller is powered off. The issue here, is that even with a low timeout setting, there could be a quite noticeable delay when using the HMI due to all of the timeouts from the process controllers that are not currently in use. I would like to use the contacts I put on the power switches to determine if a controller should be read from or written to, but I cannot do this if there is no way for me to manually check an input prior to sending any data.
Does anyone have any experience with this? My RS-485 network is already in place, and if I can't find a solution, I may have to send this back and pick a different setup.
hello, I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is...
723
I've been tasked with modifying a current hmi program for the addition being added to the cell (auto/manual ,I/O ,Status). When I try to upload...
428
Hi. We're refurbishing a used machine with a Maple HMI5070TH HMI. I'm trying to establish the log-in details. There are four users; operator...
335
Hello everyone, I have a machine I'm working on that has a Maple HMI5070NLv2 and a Micrologix processor. I have the PLC running on RS500 emulate...
1,433
Good morning, I have a small project coming up and I came across maple systems when looking for a cost effective HMI. What is your opinion on...
1,450
