Maple Systems HMI 530T
Adam303
Aug 2009
Chicago
587
Hi to All. Does anyone have or had any experiance programing a maple systems HMI? being a 530 T , or using a EasyWear500 software.?
I need help with addressing. I totaly do not understand the Write to instruction.
I have a timer that i need to write a value to. The adress would be as follow N7:0/0 In the maple system easyware 500 this adress would be the "write to address" but why do I have to have a trigger address being a bit. Do I have to place a XIC bit before the instruction that I'm trying to write to??
Thanks for all the help!
I don't know enough to give a detailed answer. Normally, all values are updated between an HMI and the PLC. A write of a timer value would be a single, manual event. The trigger bit would be a separate button - the Enter button. Pressing that button writes the value.
hello, I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is...
732
Hello friends, I’ve recently started learning about PLCs and HMIs after I acquired a Wago 750-871 with one digital input card and two digital...
20
5,643
Hi Everyone, Customer has an existing Maple Systems HMI Model HMI5104XH connected to a SCADAPack 350 PLC that I am working on. I was able to...
1,731
I currently have a Maple Systems HMI (HMI5070P) communicating over Serial DF1 to a MicroLogix 1400. The problem I have is that the HMI will not...
2,099
Hey guys, I am fairly new to industrial communications. I recently got into a project in which I have a new Rx3I with a CMM002 module that I am...
1,640
