Maple Systems HMI not responding to 2080-L50E
DuffDufford
Aug 2023
ohio
hello,
I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is transferred and the HMI is responsive.
the project is upgrade and I have updated to the AB 2080-l50e-24qwb. I have upload the ccwarc file from the 2080-LC50 update the controller to the L50E and Downloaded it to the new L50E controller. All the Same Tags the only change is the LC50 to the L50E. When the L50E is installed I have no response on the HMI.
THERE IS NO "PLC NO RESPONSE" message on the HMI
The indicators on the PLC for the IO are showing that I am Functioning as expected so is the logic when online. the Outputs are working as expect as my contactors are being drawn in and released with the PBs as expected
Switched the LC50 back in no issue.
I do have a call in with Maple Systems just looking to see if anyone here has experienced a similar issue.
Import your Tags from the LC50E unit into the Maple System and I think you will be good to go.
Maple does not see the TAGS because they are NOT linked to the NEW PLC.
I tried that it was not the issue. found a cmt2808x2 that wasnt listed in inventory updated the HMI in the EBPro project and downloaded it to the new hmi issue was resolved
Hello friends, I’ve recently started learning about PLCs and HMIs after I acquired a Wago 750-871 with one digital input card and two digital...
20
5,649
Hi Everyone, Customer has an existing Maple Systems HMI Model HMI5104XH connected to a SCADAPack 350 PLC that I am working on. I was able to...
1,732
I currently have a Maple Systems HMI (HMI5070P) communicating over Serial DF1 to a MicroLogix 1400. The problem I have is that the HMI will not...
2,100
Hey guys, I am fairly new to industrial communications. I recently got into a project in which I have a new Rx3I with a CMM002 module that I am...
1,642
I'm trying to figure out how the alarm popup works but I can't figure out what is missing to make the alarm window to stay up until acknowledged...
3,022
