Maples EZware Plus - resize keypad
irondesk40
Jan 2008
nc
630
Have a maples hmi and have some screens where i have a option for the operator to enter timer values,etc. by selecting a numeric object and then a popup keypad opens to allow the values to be entered.
I am using a HMI5100L display and trying to figure out how to resize the popup keypad so that it is not as large on the screen when it pops up.
Searched the manual and not finding any info on how to do this.
Anyone got any advice?
The 5100L has eight pre-defined numeric keypads. Keypad #3 is the smallest one. You can select which one to use and the position on the "data entry" tab of the numeric object.
If you want to get really creative you can make your own, but it's a bit tricky to get everything right.
I use Maple a lot, especially the smaller screens. Would a pop up window with display of the current value and -,+, buttons to adjust value, enter button to save and close window, be acceptable. I've done that many times when space was tight and worked like a charm.
Hope someone can lead me in the right direction. Have a machine that has a compact logix plc and a maples 5071L HMI. Machine is running fine but...
1,173
Are they exactly the same? Maples says that there product is built by Weintek but with Maples specifications. From looking at the software and...
3,063
have a project coming up that will involve using a maples hmi and a compact logix 1769-L24. In the logix5000 software i see where you have a...
1,372
Back looking at how to use a maples and a micrologix 1400 plc and create and use recipes. Was looking into this a few months ago but have been...
3,128
has anyone used a maples hmi and set up a recipe in the hmi? i have a small HMI5043L that i testing with trying to create a Ascii input object on...
2,538
