Marquee recommendations
Hi ASF,
I installed a 2706-P42R from Spectrum controls recently, and can give you some pointers if you get stuck.
If you decide to get one of these, just connect it to your network & type in its default IP address (I think that it is 192.168.1.100) and there is a webpage for configuration (password is spectrum).
If you choose the "easy" setup method, you just add some global tags to the compactlogix, and then toggle the trigger tags to make the display work.
Probably sounds easy, but it took me a while, with some help from RA support, to get it going - the documentation is a bit thin, but like anything, once you learn it, it seems easy.
Ian
Perfect, thanks Ian. Always good to hear success stories. Assuming you sourced it from NHP?
Oh no, it was sourced from Rexel, as we are in NSW.
And we have the same issue you mentioned before, with the changes from Rexel to NHP
Hi guys - my name is Dennis Holmberg with Electronic Displays Inc. in Addison, Ill. Shameless plug here. We manufacture industrial displays (message signs, counters, timers, scoreboards) that communicate with PLCs using a Gateway device. Our enclosures are made for the industrial environment. Standard in NEMA1 we also have N!2 / N4X and outdoor enclosures.
Thanks for your time.
Is it this joint? Some contact details would help :ROFLMAO:
https://www.electronicdisplays.com/
TY. No, we don't have an Australian disty, and yes all of our models can be configured for 240VAC. In fact we are shipping a set of outdoor primary-secondary displays to Norway tomorrow with 220-240 power. we have shipped to Australia in the past.
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
Hello Everyone, Does anyone have any suggestions or experince with a message board that could read a tag from a PLC, or have a PLC send a...
682
I am controlling an EZMarquee display (EZMR-2L10C-E) by EZAutomation with a L82 AB PLC over ethernet. According to their installing/setup guide...
2,053
I am trying to set up an EZmarqee with a Siemens ET200sp CPU, CM profibus and TIA v13. Using the DPWR communication block, it has an error of...
1,803
Hi everyone! I am having problem to sent message to EZMarquee(LED Display). I have already set up the profibus connection to EZmarquee(b4 bytes...
21
4,184
