MCIII Flow meter
jprimeaux3
Sep 2012
Morse, La.
I need to write 3000 to a register in a Nuflo MCIII flow meter (for a reset)via a controllogix plc using a PVP 1000. Any suggestions on the easiest way to do this. I'm new to this so any help would be greatly appreciated.
Mr. Primeaux, I have a feeling I may know you.
anyway, you are going to need some type of modbus master card in the controllogix rack, like a prosoft card, to do what you are after.
There is a prosoft card in the rack. I know how to write to it to change a register value. I'm unsure on how to write 3000 to it then back to a 0 with just one push of a button. I don't know if using macros would be the way to go. I'm not very familiar with using them.
handle it in the logic. toggle a bit that writes the 3000 and at that point either wait till you see the 3000 when it reads the registers on the next poll, or use a timer and wait a second or 2 and write your 0. just make sure when you write your 0 that you also reset or unlatch the bit that you write to with the panelview back off.
If you aren't already communicating with the MCIII modbus, I might be easier to just use a Digital Output for the reset.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
185
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
168
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
66
I can't seem to figure out how to add descriptors to I/O points on an RMC using PCCU. Say, for example, I want to use "Valve_1" as a descriptor...
81
Greetings ... someone sent me a request for some student handsouts that I developed ... turns out that I had this hosted on my business website...
147
