MD-204 HMI Panel programming issue
wrapitpkg
Sep 2008
Auburn
I have a HMI panel program that I have downloaded before into MD-204 type panels, and they worked fine. I used an old XP laptop with a 9-pin serial port. (I do not have this laptop any more . unfortunately)
I updated to a new laptop, and I cannot get my new laptop to work via a Sabrent or Prolific USB to serial 9pin to work, after trying all kinds of things.
I tried using a NUL cable to in between in case the USB to serial was different . . but it did not work.
I even took a 2nd pc to serial cable that I had and crossed switched out the #2 and #3 connectors, thinking that the two communication lines might be different with USB . . all to no avail. ( I added that extra cable after the USB/serial cable before attaching to the HMI.
Can any one out there offer any assistance . . please ?
I have tried to download other drivers for the USB to serial but still nothing works. I get "check the power and/or cable connections" after trying.
Thanks....
Mike
I am in the process of migrating an SLC5/04 system to CompactLogix using a 1747-AENTR. I have two 13-Slot SLC chassis populated as shown in the...
2,966
Hello All, Trying to troubleshoot a message instruction that’s always worked between two compact logix processors (Both 1769 L32E). I noticed...
1,144
While I'm waiting for the IT dept to wake up and examine the FW logs... I have a MSG configured to read an N12 register from a PLC5 over a cell...
1,653
ControlLogix 5575 (L75): Sudden/Repeating "Unconnected Message Timeout" (0204) This ControlLogix PLC (L75/5575) has been in operation for at...
24
10,620
I want to connect dx2048 to control logix 5572 controller using ethernet module. After all configuration I get 16#0204 error. Please provide...
2,376
