pholonitch
I am in the process of migrating an SLC5/04 system to CompactLogix using a 1747-AENTR. I have two 13-Slot SLC chassis populated as shown in the attached picture. Beginning with Slot 10 (1746-NO4I), there are yellow triangles next to the slot numbers. If I double click on the Slot 10 module, the pop-up box indicates fault code 16#0204 Connection Request Error. I compared the settings to the previous Slot 9 (also 1746-NO4I) and everything is identical. The Requested Packet Interval is at the default 20ms. Is that too fast? What else might cause this error?
The rest of the system:
Studio 5000 version 30
1769-L33ER flashed ver. 30
direct connected to 1747-AENTR
also connected to a PanelView
no other network connections
Let me know what other information is needed.
