meaning of specs in electrical wires
It just means that the 1sq mm is made up of 1 strand with a diameter of 1.13mm. 7/0.43 is a common configuration for 1sq mm and this has 7 strands of 0.43mm diameter.
Hello: One customer has an application using 1715-IF16 on EtherNet/IP for the Rockwell side and HART master for the sensor. Everything is OK and...
1,810
This is in an existing application, so stuff I've found and I'm trying to debug. I've got no Tech support contract, so can't view Tech Notes :/...
1,577
Hey guys So when im online and i look at my tag list Some values show up with a white background some show up as grey What is the difference...
1,190
Hi, Can some explain me what's the measining of this option inside hardware configuration. When should I want/need this option to be...
2,939
When setting up a generic ethernet module in RSLogix you're required to enter a number of configurations parameters like the ones shown in the...
2,946
