Measuring Ohms with Compactlogix
QvixoteRoux
Jun 2014
Reynosa
92
Hello Guys
One customer has a product that includes a coil that operates with 12 VDC, they currently are measuring current consumed by the coil and then calculate the resistance in Ohms, but now they want a separate/ dedicated Ohm-meter that can measure Ohms directly and interfaces via Ethernet/IP with the PLC.
Does anyone here has used something that can recomend? We already bought one module that was supposed to be Ethernet/IP but ended being TCP and was a pain to interface, also very slow measuring.
Any help is appreciated
Maybe an RTD module can do the job. It measures resistance or temperature based on configuration I guess.
Never tried to do it, buy you may explore
Thank you for all your answers and suggestions.
The most aproximate to what I am looking for is the Laurel that rootboy mentioned. I skipped a couple of important specs that are that the device should have a display to visually read the measurement and that it can be capable of measure Ohms by itself without the need of interpreting an analog signal, this is why we cannot use transducers (and I also use a lot cr magnetics).
The Laurels is the one we bought, already installed it but the customer is not happy with it because does not have real ethernet/ip communication and is slow to take measurements.
This might actually be better for your purpose:
https://www.laurels.com/laureates.php
It can read resistance directly, and has an Ethernet option. But that may leave you with the same communication issues.
When you say slow measurements, what period are you looking for?
Edit: And what resistance range?
I would think you can just measure current with an alarm when it changes? Change in resistance will cause change in current if voltage is constant.
I have been checking with all the answers and links provided, thanks
OK, I'll ask: Why are they doing this, measuring and remeasuring the impedance of the same coil?
o_O :confused:
I dont understand your question, customer wants a device that is specialized in measuring resistance/impedance, not specialized in current and leaving the math to the PLC, they had already problems selling defective products using the method of measuring current and calculating the Ohms in the PLC
Resistnce optimal range is between 13 and 17 Ohms already incluiding over the limits
Time for measurement under 250 mS
They currently are measuring the current when applying voltage to the coil for other testings and with this measurement calculating the resistance in the PLC, I honestly think is pretty accurate but they got this crazy idea and are putting a lot of pressure
It appears that they need a resistance test for coils. The Laurels module will make that measurement by sourcing a current (through the coil, reading the voltage drop and reporting the result as a resistance value.
That will work as long as the coil is not energized by a control circuit.
Resistance measurments need to be made on passive components, in this case the coil, not in an active, powered circuit.
Hi everyone, I don't know much of PLCs but it happened that i need to connect Leuze AMS358i Ethernet laser measurement to Productivity 1000...
1,073
Hello everyone! Firstly I'd like to say that I'm new to this forum and also new to PLC programming world altogether, that said I really would...
27
4,899
I am looking for a way to determine level in a silo. The material is called Perilite which has a very light density. Bulk density could be...
2,764
In our water cooling tank, I've installed and successfully wired up 4 float switches & updated the PLC (big thanks to @parky for that). As a...
46
11,570
Hello, I have an application where I need to measure the salt level/volume in a salt saturator. This is a fairly large tank where we load bulk...
21
6,544
