Medoc running under XP
Hi francevendee
If you are using the Dos based Medoc, then you can not run under XP.
You will need a dos prompt (MSDos or winxx-win98)
Dariusch
using the command prompt.
assuming medoc is located at C:\medoc
the command line should read C:\medoc\medoc.exe e3f12
that works a treat
Just copy all the files from the floppy to a directory on your laptop. make sure that all hidden files are copied accross too
Done all that. Problem I had was very small screen. Found solution presseing ALT-H when package opened sorted the problem.
Any way thanks all for advise.
Hi Everyone I am trying to up-/download program from/to PLC but get an error in windows. I have a F1-12MR PLC and the F2-20GF1 interface...
2,679
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
385
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
518
Is it possible to backup the devices (D,M L etc) in MEDOC? I´m going to change the battery and would like to backup before the change. The CPU is...
1,059
Just wondering what the keyboard shortcut to insert a rung in Medoc is?
1,544
