Melsec Medoc. I know it's old, but...
tony.del
Sep 2007
Witham, Essex
I am current using Melsec Medoc version 2.3 to try and connect to a F2 PLC. I'm also using an F2-20GF1 Interface and SC-03 PLC-PC cable. Now my problem is this: I'm trying to upload the program from the PLC but keep getting a message saying "No reply from PLC-System". I've sofar checked that the PLC is not in RUN, the baud rate, data & stop bits, parity and flow control settings are consistant throughout. So please can you tell me where I'm going? (Before I do something silly!!)
Tony.
If you also have Rockwell software on the same PC make sure that Linx is not running and hogging the serial port. This is the most common reason I have seen for the type of problem you are having.
Andybr
Hi
I run medoc on my dual core laptop with XP Pro
Try the command line medoc.exe e2T30F30
Cheers
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
388
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
525
Is it possible to backup the devices (D,M L etc) in MEDOC? I´m going to change the battery and would like to backup before the change. The CPU is...
1,062
Good day everyone, sorry i know this is old but i would like to receive your help with DOS MEDOC SOFTWARE or WIN version if somebody has it...
5,162
Hi, I didnt thought i would come across an A1N CPU in my life. But now i have and it is as i thought programmed in MEDOC 2.4.🙃 Is it...
2,990
