Melsecnet/10 Wireless
jasonrvt23
Oct 2006
Kuala Lumpur
Hi, I am currently using a Melsec Q2ACPU-S1 with AJ71QLP21G Melsecnet/10 network module to connect to another PLC system of same configuration. The connection between these two Network Modules are done through Fiber Optic and the distance is 1500M. We are currently planning to Upgrade the physical connection of Fiber Optic to Wireless Mode.
1) Has anyone worked with Melsecnet/10 network and can these network be made wireless. What modules are there to do this convertion?
2) Our intention is not to interfere with the existing PLC program and hardware modules. We are planning add additional modules to make these connections wireless. Currently, I found out several modules which does Fiber to Ethernet convertion. I.e. FO to RJ45 convertion. By doing this, I would be able to use currently available of the shelf wireless modules to do the wireless connection. This would be done under the Wireless Bridge connection. Only thing I am afraid is the convertion of Melsecnet/10 network....will there be any inteferance to data?
Jason
Hello all, I have 7 Q series PLCs on a Melsec net/h network, Ladder Programming none of that fancy smancy ST stuff LOL :p. Were running the...
1,406
I have previously used a A1SJ71AP23Q card to bridge MelsecNet 2 to Q PLC. However, our local supplier told me that card is now obsolete. Has...
1,228
I currently am working on a project that involves adding CC-Link to an existing system that uses MELSECNET/H coax network. I have a small scale...
2,582
Hi guys, Good day! I just visited a plant wherein a Ship Unloader control is required to be rehabilitated. Existing PLC is Mitsubishi A Series...
1,530
Hey, I have some questions about melsecnet-mini. The CPU is A2A and it have some stations in a melsecnet-mini network. The master is a AJ71PT32-S3...
1,846
