Memory Clock Edge Generator
[PL] mk
Apr 2017
src
I'm not got at STL and I have a little problem.
I want to create FB generating edges for PLC memory clock timer. On FB inputs you just have to assign the integer value for memory clock address and byte number where do you want to have the edge from memory clock.
Problem is with creating coil from edge.
When I detect the timer state using stat memory called "edge" the "mc" bit (in example bit 0.5) is transfer to "mce" and "mce" bit acts like "mc" - like a normal memory clock bit.
When I assign M memory bit to detect edge, everything works correctly - bit 5 on "mce" is an edge signal.
Can somebody tell me where the problem is?
Oh...in addition when I use the stat memory to detect this edge I recive "Area length error when writing".
VAR_INPUT
mc : INT ;
mce : INT ;
END_VAR
VAR
edge : BOOL ;
END_VAR
Code:
L     #mc                         // in my case 5
SLW   3
LAR1
L     #mce                       // in my case 265
SLW   3
LAR2
A     M [AR1,P#0.5]        //m5.5 address
FP    M    266.0             //in this case everything works
//      FP    #edge         //in this case I recive are legnth error when writing
=     M [AR2,P#0.5]
Diagnostic buffer:
Code:
Event 1 of 10:  Event ID 16# 2523
Instance DB, bit access, Access address:    269
FB number:      3
Module address:     22
Requested OB: Programming error OB (OB121)
Priority class:  1
Internal error, Incoming event
10:00:24.601 AM  04/30/2017
(Coding: 16# 2523  0179  8E05  010D  0003  0016)
AR2 is used inside of FB-blocks. You modify AR2 value to 265. On your FP call of stat variable "edge" points now to AR2 + Offset, which block have maded on start. (I Assume that edge have address 4.0 on stat configuration so after AR2 modification CPU search edge from P#265 +P#4.0 (269) instead of P#0.0+P#4.0)
If you want use AR2 register, you need save and load its value on start and end of your own change. Also AR2 manipulation needs to move different place.
https://support.industry.siemens.co...iables-after-saving-the-block-?dti=0&lc=en-WW
http://s7tools.com/index.php?option...n-block-fb&catid=17:tips-and-tricks&Itemid=30
http://s7tools.com/index.php?option=com_content&view=article&id=22%3Afb-call-qbehind-the-scenesq-&catid=17%3Atips-and-tricks&Itemid=30
You can modify your code only to use AR1 register or use Dword variables instead.
SLW 3
T #index1 //stat variable index1 (Dword)
SLW 3
T #index2 ////stat variable index2 (Dword)
L #index1
L P#0.5 // or maybe L L#5?
T index1_and_bit
L #index2
T index2_and_bit
A M [index1_and_bit] //m5.5 address
// FP #edge // edge
= M [index2_and_bit] //M265.5 address
You were right with the address shift after AR2 modification.
Anyway. I corrected the code according to your suggestion and now it works fine.
The question is whether such a programing have any sense?
It's hard to find such signals, and anyone who is not familiar with the program can use this address area and disturbed program functionality.
Code:
      SLW   3
      T     #index1
      SLW   3
      T     #index2
//Prepare memory clock address
      L     #index1
      L     P#0.0
      +D
      T     #MClock0
      L     #index1
      L     P#0.1
      +D
      T     #MClock1
      L     #index1
      L     P#0.2
      +D
      T     #MClock2
      L     #index1
      L     P#0.3
      +D
      T     #MClock3
      L     #index1
      L     P#0.4
      +D
      T     #MClock4
      L     #index1
      L     P#0.5
      +D
      T     #MClock5
      L     #index1
      L     P#0.6
      +D
      T     #MClock6
      L     #index1
      L     P#0.7
      +D
      T     #MClock7
//Prepare memory clock edge address
      L     #index2
      L     P#0.0
      +D
      T     #MClockEdge0
      L     #index2
      L     P#0.1
      +D
      T     #MClockEdge1
      L     #index2
      L     P#0.2
      +D
      T     #MClockEdge2
      L     #index2
      L     P#0.3
      +D
      T     #MClockEdge3
      L     #index2
      L     P#0.4
      +D
      T     #MClockEdge4
      L     #index2
      L     P#0.5
      +D
      T     #MClockEdge5
      L     #index2
      L     P#0.6
      +D
      T     #MClockEdge6
      L     #index2
      L     P#0.7
      +D
      T     #MClockEdge7
//Generate edge
      A     M [#MClock0]
      FP    #sEdge[0]
      =     M [#MClockEdge0]
      A     M [#MClock1]
      FP    #sEdge[1]
      =     M [#MClockEdge1]
      A     M [#MClock2]
      FP    #sEdge[2]
      =     M [#MClockEdge2]
      A     M [#MClock3]
      FP    #sEdge[3]
      =     M [#MClockEdge3]
      A     M [#MClock4]
      FP    #sEdge[4]
      =     M [#MClockEdge4]
      A     M [#MClock5]
      FP    #sEdge[5]
      =     M [#MClockEdge5]
      A     M [#MClock6]
      FP    #sEdge[6]
      =     M [#MClockEdge6]
      A     M [#MClock7]
      FP    #sEdge[7]
      =     M [#MClockEdge7]
Before you can use and modify STL and indirect addressing, you need to know lot of what PLC does. You can use AR1 and AR2 if you know what they also do and what can happen when using them inside FB.
You could also use loop on your code, but then it goes more unclear.
You can put AR1 and AR2 inside of FC-block (again save and load registers), Call FC then on FB networks. You FB stays then clean of all indirect addressing.
Thinked little bit more. If you want make edges for every bit of byte and save edges to different area, then it would be easiest without indirect addressing:
"oneshotbyte" := "sourcebyte" AND NOT "membyte" ;
"membyte" := "sourcebyte" ;
http://www.plctalk.net/qanda/showthread.php?t=76887
That way everyone also see where bits are writed. (From cross reference or Search/Go to (Overlapping access to memory areas selected).
I would use memory marker area for this, so that you can have symbol name for byte and individual bits.
Hello I need to make a pulse every second of RSlogix the 5000th I have read this thread through and tested it as rdrast writes in Post # 14...
6,070
Hi I need clock memory in s7-200 plc. I found SM0.4 30 s off / 30 s on and SM0.5 0.5 s off / 0.5 s on but they're not good because I need 1s off...
4,157
Does someone know how the clock memory in Siemens works? I tried to search specifications from S7 programming manual, but there was no information...
9,752
I am kind of new to GE products, but we have several in my area. I made a minor logic change and it verified good, but when I tried to download I...
36
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
80
