Memory Error - Micrologix 1400
Sphinxj
Jan 2014
Washington, MO
24
So I am trying to download a program to my processor and I get this error:
Program error ERROR: The program has exceeded the memory limit of 10K user words.
From what I have read, I may have too many data files?
What else I have noticed is that when I look at the controller properties, I just get a * for memory used and memory available. This program is a modified program from a different machine and I suspect that may have something to do with it, but I am not for sure. I have attached an image of the controller properties. Any ideas?? I can't download the program to the processor until this is fixed... šŸ™ƒ
Thanks in advance for the help.
right click on the data files folder and go to properties. that is where you check the user words limit that the error is talking about. It will also show you how many words each data file is using.
Also, if you verify the program, it should recalculate the sizes and fill in those "*" unknowns.
In the project tree, right click on "Program Files" and click "Verify Program".
I am using a Micrologix 1500. Base unit: 1764-24BWA Processor: 1764-LRP Memory Module: 1764-MM2 I have downloaded the program with only S:1/10...
4,140
Hi , we try to get a CPU 317T-2 D back to life,memory card was defective and with some resets we have only sf light red flickering we...
28
741
Hello all, we tried to connect Proface GP 4301TM and a microcontroller via Ethernet, using TCP protocol. We wrote "uint8_t...
1,840
The tech onsite got the above message during an online edit and he had to back out the edit. This is a first I seen this, I did search RA KB and...
6,401
I have customer that has about 30 Modicon Quantum 534's in their factory and running flawlessly since 1990. Over the years there has been two or...
1,967
