message 24 on Panelview AB
Deer
Jun 2002
124
Hi All,
I have Panelview 900 (2711-T9A1),I have make some modification program on this Panelview using the panelbuilder software.
After that, I was download this program to the Panelview900, and I recycle power.When this panelview count some numbers,this PV stop count on 24, and give a " ERROR! FEHLER! ERREUR! ERRORE!" message.
I know, 24 is about firmware problem/corrupted.
To solve this problem, I have try to download or upgrade the firmware to the panelview, and the problem was solved.
My question, what caused so firmware can corrupt on the panelview ?
Many thanks
Deer
What changes did you make?
Did your pv900 selection in the panelbuilder software match the firmware verson of the actual unit?
I suspect not....
although really, just a guess
Ndziedl,
Okay, I am just add some objects to the panelview screen through panelbuilder S/W.
Actually this panelview already running almost one year with no problem, but when I add some objects and redownload this program, cycle power,panelview give me an error.
My concern is why a firmware can corrupt or damage ?
thanks
Deer
I have seen software revisions not be fully compatible with earlier firmware. Did you use the exact original revision version of programming software for the original program development as the editing changes you just made? If the programming software was upgraded then the firmware upgrade probably brought everything back together to be fully compatible.
I hope this helps,
Sid
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
135
Hello, I was wondering if anyone could let me know how to change the audit trail messages language on Factory Talk ME. I am currently working...
464
Hello, I come here to get some help on my search for one or more problems on my machine. I am totally beginner and I am currently discovering...
54
13,277
Hello, I have been lurking here for awhile and can usually find the answers to my problems. I'm doing my first PanelView application using...
1,263
I have been requested to code an operator set point entry check as follows. This may be simple but has me baffled at present. control system...
2,890
