Metal sheet temperature measuring
Nak
Jan 2004
Schagen
20
Have someone a solution to measure temperature of a metal sheet what's moving approx 15 m/min ?
Due to colors and variations in the sheet, the emission factor for IR-measuring is changing too much.
I want to measure within 0.2 degrees celcius.
Regards, René
Those accuracy specs are for the full temperature range of the device.
You can get much tighter by calibrating within the range of interest.
Response time may be an important consideration when comparing different probe types.
For thermocouples calibration is only valid until the next time it is heated up. you cannot guarantee calibration on a thermocouple tighter than the limits i have quoted. 0.2 deg C accuracy I do not believe is achievable in an industral environment.
RTDs are a lot slower response than thermocouples unless special designs are used.
I agree that .2 C won't happen. I strongly disagree about themocouples.
Yes, there will be a shift if it's cooled and heated, but not a 4 degree C window. The major shift occurs at the range extremes, such as -200C for a type K. If you stay within a typical range of 50C or so, and calibrate in that range, your results will be much better.
I have a client who purchased a sheet metal bending machine from a company called IMS-Powerfold about 16 years ago. It looks to me like the...
24
12,141
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,157
Good Evening , We had a Mettler Toledo Safeline Metal Detector acting unstable last week . We brought Mettler Toledo in to look at it ...
843
Currently my company has a MT metal detector model V4 that has been down for the better part of a month. The metal detector is giving a F06-5 IO...
3,135
Good Morning , We have a new Fortress Stealth Metal Detector. About 30' away we have a machine with motors and solenoids on it , Whenever...
2,210
