micro 1100 communication
jcole28
Jan 2018
Kentucky
Good day Guys and Gals.
Trying to connect to micrologix 1100 using USB to serial adapter . Cannot seem to make a connection. Is it possible I need to update or install drivers for RSlinx to communicate with the USB port?
Couple of things -
The USB to serial will show up as a com port in Device Manager, It probably won't be Com1. It might also change port #s if you move it around.
You'll want to use the DF1 driver, assuming your ML1100's port is set to the default out of the box.
You can also use ethernet to talk to the ML1100, and I find it a lot easier.
also make sure you have the driver installed for your usb to serial adpater. Then like Dravik said it will show up in device manager as a com port use that port in your DF1 driver setup
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
478
I'm working on a project currently that is requiring me to log a username and a and number. I need to MSG a string file, the username, and an INT...
2,078
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,088
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,723
Is it proper to use the S:4 instruction ie: S:4/12 for a flasher?
1,714
