Micro 1100 Enet Programming Port?
Jason Ozolins
Mar 2012
Fife Lake, MI
59
Anybody know the port number when using port forwarding to access the Micro's Ethernet thru a radio/modem.
I believe I saw somewhere 44818 & 2222... This correct?
The MicroLogix 1100 and 1400 controllers use only TCP Port 44818.
Port 2222 was used by old PLC-5E and SLC-5/05 controllers, but is not open on any of the modern MicroLogix, ControlLogix, or CompactLogix controllers.
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
478
I'm working on a project currently that is requiring me to log a username and a and number. I need to MSG a string file, the username, and an INT...
2,080
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,091
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,723
Is it proper to use the S:4 instruction ie: S:4/12 for a flasher?
1,714
