Well, what I'm trying to do is start and stop my program using a start and stop button (physical). In a SLC500, which is the only other PLC I have experience with, I would use an internal bit (B). I would designate an internal output as B0 and then use an internal contact (B0) to start the program. I'm trying to do the same thing with the set and reset bit. I want to use the start button to set an internal coil and the stop button to reset it. I didn't realize they can be earthier internal or a physical output, but it should work either way shouldn't it. The way I have it set up (actual output) I should still see it energize when I close the contact?
