Micro 820 and Panelview 800
Brad7778
Jun 2017
Brandon
Hello I am new here and very green with plc's. I have dealt with them in school for my electrical apprenticeship and that is the only time.
To get to my question now. I have a micro 820 that had it's LED's flashing and seemed to be in working order yesterday. I turned the disconnect off for the night and now it won't come back this morning. I checked my voltage and it is within the suitable range.
Next I have a Panelview 800 2711r-t4t and I have the 24vdc to it and it doesn't want to even show me any signs of life. What could I be missing?
Thanks in advance.
Brad A.
More....
Can I hook up the 24vdc and leave the communications not hooked up. Or does everything have to be hooked up for it to turn on?
Something should happen if you apply 24VDC to it, it shouldn't be dead if it's working at all.
It's strange situation. I replaced it with another Panelview and it's still doing the same thing, the only light that blinks is the fault light when I turn the power off. The other equipment that requires the 24vdc is working.
Did you measure that you actually have 24V at the panel when the power supply is connected to it and all other consumers?
Another dumb one then, did you measure AC as well? Just to confirm there's no AC at the same time.
Weird with 3 different things breaking and not being something they have in common :(
I am just using a 120v to 24v transformer with a bridge rectifier and a diode for surge suppression. Should I be using a specific power supply?
Try change the power supply to a switching power supply. You wont get a good DC voltage with transformer. I have tried a similar setup once and also experienced problems.
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
302
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
375
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
1,005
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
490
