Micro 850- Model 2080-LC50-48QWB
chandrapaul
Mar 2016
bangladesh
119
Dear All,
my client has a allenbradley plc Micro 850- Model 2080-LC50-48QWB. can i program it using rslogix500? during opening new project which processor type should i select? need your help...
Thanks in Advance
chandrapaul said:
is the micro850 better than micrologix series plc, like micrologix 1000
AustralIan said:
the micro850 is better than a MicroLogix in some applications
But more so.... its still manufactured and the 1000 is not
The more I use the software the more I like it... it does take a little time to get the hang of but its not bad now that it does not crash anymore, that was terrible o_O
is the making ladder program similar to the rslogix500? i worked with rslogix500. can i adapt the ccw also by myself using the rslogix500 work experience?
I am trying to read and write data from Control Logix L23E and a Micro 850. My path in the message is 2, 192.168.2.183 192.168.2.183 is the ip...
721
Hello. I have an issue with a Micro 850 PLC. Issue is when it is in RUN mode, and an output is energized, the whole PLC just turns off, then turns...
852
560
I am using a Micro 850E PLC (the new one with implicit messaging capability) to drive a Kinetix 5100 servo drive. The error code number on the...
1,731
Hello, and thanks in advance I am working on a project with two micro 850 controllers and want to send bool bit from one to the other. I am in...
1,149
