Micro Logix change to Compact Logix. G3 Changes?
Bullzi
Jun 2012
Colorado
1,530
Hi all,
I have started a project with programming a Red Lion G3 that will be connected to a MicroLogix 1200 via a ENI-NET. Because of expansion limits of the 1200 we are going to change the PLC to a 1796-L30-ER.
Since I have never worked with the Compact Logix before I have a few questions:
  1. What Ethernet driver do I use? I used DF1 via PCCC/IP on the 1200.
  2. Will I have to make my tags in the HMI Database match the tags in the PLC?
  3. Are there any other changes I need to make to the HMI program to make it work with the new PLC?
Thanks for any help you can provide.
Chris
Hi all,
Most likely, you will choose the "Allen-Bradley Native Tags via L5K file" driver. Then you can get all the PLC tags into your crimson project by simply doing a save as L5K type in RSLogix5000, and then import that file in Crimson on the Communications page.
No, they are independent things. A G3 tag can certainly have its data derived from a tag imported from your L5K file, but they don't have to be named the same. Or, like direct references in FTView, you could just populate objects with the L5K tags directly.
Just the drivers and communications settings as far as I know. You'll want to read up on the L5k export/import process and that's it unless I am forgetting something.
Thanks for the info Okie!!
I have finally found the time to mess with this. I have a few questions that hopefully you can help me with:
1) Is there a faster was to import the tags than to go to "Manage Tags" and add them one at a time? Can I just import them all at once?
2) Under the "Target Device" on the communications, there is a TCP port shown as 44818. Is that a default port? Will that work for my L33?
Thanks for the help!!
Chris
I have someone out in the field and need him to change the gateway of a micrologix 1400. It currently has the correct ip but needs a gateway which...
1,699
I'm working on a project currently that is requiring me to log a username and a and number. I need to MSG a string file, the username, and an INT...
2,080
Hello all, I purchased the RSlogix 500 micro version yesterday. I got the download and activation link through the mail. A 512MB file got...
2,496
Hello, first assignment with A-B stuff. The CPU is a MicroLogix 1000. Have a serial interface, so RS Linx Classic to edit the driver (AB-DF1) with...
1,705
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,214
