micro820 message send iP
Giogio
Jul 2013
Italy
hi
I wanted to know if it was possible to exchange data between two micro820 via ip , I have not found any function that allows this .
You know help ?
Thank you very much Noxcuses
It was just what I was looking for , but there is only one issue that I should send the data and buy from decimal numbers , if I use the function DINT not good because it does not accept them , and this with all types of arrays .
Do you know how I can risolver ?
thanks again
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
833
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
175
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
912
Hello, I am using a AB Micro820 PLC, via the SD card I want to update the PLC program (not FW). First I created a text file on the SD card with...
304
