Micro820 how to get back in Run Mode via SD card?
MauritsKoppe
Feb 2023
netherlands
Hello,
I am using a AB Micro820 PLC, via the SD card I want to update the PLC program (not FW).
First I created a text file on the SD card with the name ConfigMeFirst.txt, to backup the program from another 820.
Then changed the ConfigMeFirst.txt with:
[IPA = 192.168.1.40]
[SNM = 255.255.255.0]
[GWA = 192.168.1.1]
[RSD = Micro820QWB]
[END]
Inserted the SD card into a new 820. I do believe the programming was done correctly.
My problem is that the 820 stay in Program Mode. Even after several power cycles the green Run led stays blinking indicating that the unit is in ProgramMode.
It did change the IP address from default to the above.
How to get the 820 in Run Mode again?
Thank you.
Thank you for your reply, it works now.
New units comes by default in program mode, which makes sense :)
You either need to switch the unit to Run mode, this can be done in ccw or select Remote Run Mode in Mode Behavior to always start in Run mode after a power cycle.
From now I will always select Remote Run Mode.
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
818
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
170
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
903
Hi New to PLCs, up until now I have played with smart relays and the siemens S7-1200 line with TIA. I am trying to get a AB Micro820 to talk to...
305
I have run into a problem with my first time installing a 2080-OF2 module on a Micro820 and have a hunch that the module itself - brand new out of...
931
