MicroLogix 1000, AB 1761 NET ENI and Citect
elroydaman
Guest
E
Can Citect talk to an AB micrologix 1000 sitting on an Ethernet network via the AB 1761 NET ENI module? No drivers are listed for Micrologix at all in the Citect driver database, although I understand that DF1 comms are supported as well as TCP/IP for other PLC's in the AB family.
Anyone run into this before? Appreciate any info pro con or otherwise!
Thanks,
Elroy
Citect ought to treat the MicroLogix 1000 and 1761-NET-ENI as an SLC-5/05 via it's Ethernet driver. That's what RSLinx does.
Hopefully a Citect user with this setup will be able to weigh in.
Are you saying I should be able to pick the SLC/505 and TCP/IP communications setup in the Citect comm menus?
If true, that sounds too easy!
Regards,
Elroy
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
145
I want to connect an AB Micrologix 1000 with my PC through AB 1761-NET-ENI series D module (no other deive in the network). PC TCP/IP settings...
8,301
how to connect thermocouples in micrologix 1000 1761-L20BWA? pleace help
3,497
Is it normal for the fault LED to light up for about 1 sec at power up? The PLC works great and I don't see any obvious problem with it.
3,088
Hi all, I've been a long time reader on the forums but need to ask for some help. We have many Micrologix 1000 around site and wanted to put...
6,482
