MicroLogix 1000 and HHP
XtremeIN
Jun 2005
Indiana
217
Hello all,
I have working with various PLC's for the past 10 years or so. In that time I have never used a hand held programmer. Yesterday I was challenged by a coworker to write a simple program using the HHP. For the most part, not so bad. But, I am having one small issue. I decided to one-up him and add some extras. I am trying to use a EQU function referencing the .ACC of T0. How do I enter/call up the .ACC?
Thank you,
Micheal
Hi Micheal, try this...
First go in to Program Monitor to edit your Instruction List:
Press MON ENT
Navigate to the point where you want to insert the Equal.
Program in your Equal instruction, whether it's:
LD EQU - key in: FUN 50 ENT
AND EQU - key in: FUN 51 ENT
OR EQU - key in: FUN 52 ENT
You should see SRCA (Source A) for the EQUAL instruction.
Then there should be a '↓' or '*' on the display, can't remember which? I think the '↓' means there are more options available and the '*' means a number has to be entered?
Use the '↓' I think? to select 'T' for timer and press ENT
Then I think there should be an '*' on the display, meaning it's waiting for a number.
Press '0' for T0(T4:0) and press ENT
Now you see '↓' again
Choose '.' for sub-element delimiter and press ENT
Use '↓' again to choose 'ACC' and press ENT
Now you move on to SRCB (Source B)
Follow the same steps, if they worked, to enter Source B.
That might not be 100%, but it's something close to that, if not.
I've attached the format for timer addressing, so it is possible.
G.
Thank you Geospark,
After I add the EQU (fun 50) I do get the SRCA in the upper right and a flashing cursor in the bottom left. No down arrow or *. I enter T0 and still just a flashing cursor. If I press the ORB button it gives me T0/ with DN(down-arrow) and I can scroll through DN, EN, and TT. Still cannot figure out how to enter .ACC. I do not see a key with a "." on it......
Micheal
Micheal,
Can you try entering 'T00' instead of 'T0', then see what cursor you get?
G.
Thank you for your help G. I just figured it out. After keying T0 I pressed the FAULT|PRE/LEN key. It gives me the arrow option to select the .ACC.
Micheal
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
156
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,267
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
992
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,422
Hey Folks, I have a customer with an older machine that is controlled with a MicroLogix 1000. The machine just quit working. The power light is...
22
10,603
