Micrologix 1000 and PV550
LStewart
Apr 2005
Mississippi
95
Okay people I have another question for ya'll, I am wanting to use a micrologix 1000 and a pv550, I am choosing the micrologix because its cheaper, smaller, and will do what I want. I am choosing the pv550 because we have one taking up space in a cabinet and I would only have to buy 1. Now for my question, what do I need to make the micrologix talk to the pv550? I have worn out the Rockwell website and still haven't found this information.
Thanks in advance for answers, suggestions, and remarks!!
Lori
You can configure the MicrLogix com port for RS-232 DF1(factory default) and use a 2711-x5A16 PV 550 (x=K for Keypad T for Touch or B for both). Connect them with 2711-NC21 cable. Or you could configure the MicroLogix port for DH-485 and use a 2711-x5A5 or 2711-x5A9 PV 550 and connect with 2711-NC13 cable. There are other possibile combinations on the DH-485 option if you think you will ever need to network other DH-485 devices with your ML/PV.
I can help you better if you could tell me the part number of the Panelview 550. There are a few different Panelview 550's with different communication ports.
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
151
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,262
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
991
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,419
Hey Folks, I have a customer with an older machine that is controlled with a MicroLogix 1000. The machine just quit working. The power light is...
22
10,591
