micrologix 1100 hmi program
Nagadev
Feb 2015
I was using Allen bradley touch HMI in a highly rugged environment which caused repeated failures in HMI, So to avoid the same, I have changed the HMI to Desktop PC and made the HMI application running in it. But now coomunication between PC and PLC is been losing out more than 5 to 6 times a day which makes application closed and restarting. Please provide me a solution.
Do you know what errors you are experiencing on the PC? Is it a communication fault, error on the program, etc.
You may have other programs running that may affect the program. You could have a communication fault from noise. (Cable shielding should be checked.)
Regards,
Garry
http://www.accautomation.ca
A desktop pc is not more reliable than an HMI. IMHO you are going backwards but!!!.
What sits between this pc and the PLC? is there a switch, router,firewall,anything?
If it's nothing but a crossover cable connection check your cables.If it's a homemade get a premade patch or crossover cable.
Many people think they can make reliable ethernet patch cables and the truth is very few can.
I’m new to plc programming and very new to HMIs. So this is what I have done so far: I bought a micrologix 1100, I used bootP to set the up...
17
1,680
Hello everyone, I have a machine I'm working on that has a Maple HMI5070NLv2 and a Micrologix processor. I have the PLC running on RS500 emulate...
1,433
Hi, I have a project where I'm replacing a faulty Mitsubishi FX3s plc with a Micrologix 1100. The FX3s was using a GS2107-WTBD HMI panel. The HMI...
1,113
Good Morning, How can I conect with ethernet Siemens KTP400 with Micrologix 1100 allen bradley
1,573
3,700
