Micrologix 1200 HSC with Linear Encoder
Fourpaw
Mar 2007
Florida
54
Anyone have experience with the Micrologix 1200 HSC and linear encoders?
I have 2 questions...
1. I have output signals A, B, Z... coming off the sensor.
Incremental signals = 2 square-wave signals A, B and their inverted signals A-, B-
Reference signal = 1 or more square-wave pulse Z and its inverted pulse Z-
How do these apply to what the HSC needs to see and what terminals do I wire these to?
2. The encoder sensor I have is open collector so there needs to be a drop resistor to create and limit the current.
Max current needs to be 20mA so I want to calculate the resistor for about 15mA (@ 24VDC).
Is there a PLC Input internal circuit resistance I should be concerned with? What terminal connections do I terminate the resistor on?
i.e. PLC Input internal circuit resistance + external resistor needs to result in a max 20mA load at 24VDC (so target is about 15mA).
I am doing a PF correction and am using a micrologix 1200. I am trying to find the difference between 2 counts from my high speed counter. Is...
1,160
Question about HSC in Micrologix 1200. I am trying to program a HSC in a Micrologix 1200. I can set it up in the function file and see the...
3,483
I am faced with a situation that will require using the HSC instruction with a PID instruction both of which I have never used. The HSC will read...
3,705
Hello All, I'm having my first experience with the ML line and their HSC function. It took a bit of head banging but I finally figured out how to...
3,550
This seems like an easy one but I haven't found the answer yet. I have a micrologix 1200 and a program which uses a STI and IOM to control some...
3,923
