Micrologix 1200/slc 500
lab
Nov 2003
48
I wondering about timers in rs logix 500. My question is if I use a ton command and would like an output to come on when the acc of this timer hit a preset value, and would like the timer to keep timing to it pre determined value, how can I capture this and turn on my output while the timer continues to time?
Thanxs in advance
Lab
Could use a compare instruction (EQUal to/GRT than etc) to look at T4:X.acc then latch a bit when the compare is true............just one of (what i'm sure will be ;)) several ways to skin this particular feline! :)
A timer uses status bits and internal words to the timer function. The words are ACC (accumulator) and PRE (preset). The bits are /DN (done), /TT (timer timing), /EN (enable), and a bit for the time base. The timer times when the function is powered by the logic. The DN bit is set when the ACC is equal to or greater than the PRE. Even though the DN bit is set in this condition, the timer keeps timing and the ACC continues to go up until the logic interrupts power to the function.
You could use the DN bit in your application.
Several times I have used one timer to activate sequential steps, use the compare on the timers' accumulated value then a GEQ to activate the logic you want to activate at a certain accumulated value, this was already said. I hope I have explained it's use better.
Thanxs for all your reply's. I'am wondering about something I read in the rs logics manual, I'm not sure what is meant by this, maybe someone could explain, what's an accumulation bit is this t4:0.acc?
or is this a register that the timer uses for it's acc?
Thanxs
Best regards
Lab
Timer T4:0 is actually made up of 3 16 bit words
T4:0
Bits 0-12 are reserved bits
Bit 13 is the Timer done bit (T4:0/13)
Bit 14 is the Timer Timing bit (T4:0/14)
Bit 15 is the Timer Enabled bit (T4:0/15)
The entire second word is where the Preset value is stored (T4:0.PRE)
The entire third word is where the Accumulated value is stored (T4:0.ACC)
So T4:0.acc just a place to store the information
Basicly what Mickey said (wish I could have typed a bit faster)
Afternoon All, I am working on a Project to bring I/O from a MicroLogix 1200(1762-L40AWA) to a SLC 5/05 (1747-L551)NOTE all of this work is...
2,452
I have written a few BASIC programs for the SLC 5-02/04 units years ago, I have now got a MicroLogic 1200 that I have to write a program for. Is...
1,831
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
710
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
522
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
765
