Interfacing MicroLogix 1200 to SLC 500
Rockivy
Feb 2010
Edmonton, Alberta
Afternoon All,
I am working on a Project to bring I/O from a MicroLogix 1200(1762-L40AWA) to a SLC 5/05 (1747-L551)NOTE all of this work is Brownfield so big changes aren't in the cards
I also have a 1761-NET-AIC+ interface with the MicroLogix module
I'm looking to use the DH485 from the AIC to connect to the SLC, Is this even possible? From checking the AB documentation the 1747 and the 1762 are DH485 enabled can the IO maps be sent from the 1762 to the 1747 so that we can read the IO?
This is a fairly stock question on these forums. A quick search should yield a myriad of responses with all types of troubleshooting/design q/a.
Hello Experts !! Greetings, Hope you all doing great !! I want to Interface Multiple (Upto 10 ) Barcode Scanner Serially to PLC Micrologix 1400...
2,660
I was wondering if it was possible to take allen bradley micrologix plc's and interface it to ge cimplicity hmi's. If it is possible what do I...
2,040
Hi there, I am developing an application which requires interfacing to a PLC.I will be producing quite a number of the same machine each year. I...
1,571
Have anyone done an data exchange between a Micrologix 1000 and a S7-3xx ? I guess hardware-wise is possible to use a DF1-to-Ethernet to put the...
3,513
hello there, can someone tell me how to interface allen bradley Micrologix 1500 LRP series C PLC with Siemens Protool for runtime data...
4,549
