MicroLogix 1200--where is the programming port
Skidood
Oct 2016
Ontario
215
Hi, The MicroLogix 1200 has a Com 0 port and a "HMI/programming port". When looking at the PLC, there is a port on the left side and a port on top (on the front face). Which one is which? This is not addressed in the manual and I don't have one here to look at. Thank you!
I have the manual...not the PLC...the manual does not clearly indicate which is which. Although if I had to bet money on it, I would guess the Com 0 is the one facing up and the programming port is on the side.
All ML's use the Mini8DIN for programming. It also can be used for a HMI.
I was called to a shop where their guy [Bubba] was suspecting the port had failed because RSLinx DF-1 could not connect to it. A quick check where the Mini8DIN cable plugged in it already went and see it went to a PanelView 550 - K5, which is DH485 ONLY, so the port was changed.
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
719
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
523
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
765
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
688
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,295
