MicroLogix 1400 and Red Lion LSQD 0100 Encoder
JiNCs
Jul 2007
South Carolina, USA
66
Hey guys!
Been awhile since I visited. Been out of it for a bit. Good to be logged in again.
I have a MicroLogix 1400 Series A PLC with a Red Lion LSQD 0100 encoder connected to high speed inputs 0/00 and 0/01 to measure yardage. The encoder has open collector outputs whch require pullup resistors for the 24vdc supply. My calculations show the frequency of the encoder pulses to be around 100hz equating to around 20 yards per minute.
It appears that at lower speeds (0-15ypm) the PLC counter in the PLC works OK but at the higher speeds (15-20ypm) the counter is in error.
Are the resistors likely to be the issue or is this a frequency problem associated with shielding and etc? Can anyone help with the calculation of the pullup resistors?
JiNCs
I an new to this: I am trying to finish a project. Here is the tagname Data type Address Controller PUMPA_XS...
3,720
I am having trouble communicating a set of alarm tags from the micrologix 1400 to the crimson software. All the other tags read just fine and give...
1,661
Hi guys, it's the noob again. So i'm currently in the middle of communicating between a Micrologix 1400 PLC (programmed via rslogix 500) with a...
4,814
Hello Everybody. Can some body let me know whether a Servo drive can be controlled through Ethernet or devicenet using Micrologix 1400 PLC? if yes...
2,951
Hey everybody, can't seem to get this working. I have a Red Lion G310C210 connected to a Micrologix 1400 via Ethernet. When I push the buttons I...
2,592
