Micrologix 1400 Ethernet to PLC 5/30B DH+
Oct 2007
Brisbane
Can anyone help, I would like to know if it's possible to communicate and send messages between a Micrologix 1400 and a PLC 5/30B. The PLC 5/30 is on a DH+ network and goes to a 1756 DHRIO/D at slot 1, slot 0 is a 1756-ENBT/A and slot 2 ia s 1756-L61.
So because I and see the PLC 5/30 at node 12 from my computer via Ethernet through the bridge, can I have the Micrologix connected to the ethernet network and send messages to the PLC 5/30 through the same bridge. We are using RSLinx Classic Gateway 2.55.00.16 CPR9 if that's any help.
I know I can use the 1756-L61 to read from the Micro 1400 and write to the PLC 5/30 which I have done. I was wondering if I could go directly from the 1400 to the 5/30.
any replys would be most helpful
Cheers
I have a Micrologix 1400 to which Ive assigned a specific IP address. Now when I am trying to configure it in Rslinx, i cannot find it under...
37
10,547
Hello, I'm looking for some insight on data usage for Allen bradley IP messages. I have a setup of 4 total Micrologix 1400s. One is the master...
8,122
I have 5 systems that include a ControlLogix PLC and a Micrologix 1400 PLC. I need to connect these two via ethernet. I want to have two inputs on...
1,786
I need to establish an ethernet communication between Microlgix 1400 & 7 Segment Display. Need a suggestion regarding the same.
2,554
No switch/router. Just a direct connection. I did this successfully a few month ago, but I can't seem to remember how I did it. The steps I took...
2,114
