Micrologix 1400 - HMI communication
The gender has nothing to do with it, obviously you need the proper gender to make the physical connection. But to make a null-modem cable it is the electrical connections that matter.
Pin 2 to 3
Pin 3 to 2
Pin 5 to 5
Just like your link shows
That's all you need to do to make it a null-modem cable.
In the ''Controller properties" dont have the DF1 driver.... is it required? I think that is not required.....
If your PLC is configured for DF1 protocol then use comm 1 on your HMI.
Controllers properties is showing you what was used the last time you communicated with the PLC from your PC. It has nothing to do with your HMI.
The error messages still keeps on there. Please, see the all configuration displays od RSLogix and HMI. What is wrong? Thanks
When you searched the forum for a similar problem, did you see my thread a few days ago describing communication problems for the same model of plc? I had a lot of tries with the full duplex before rtfm for my hmi and successfully using half duplex and node number.
Hi, I am using a Micrologix 1400 for a project, and we were supposed to use a 4.3in PanelView HMI. By means of delivery times, that won't be...
984
Hello, I'm trying to send recipe from my Delta HMI to Micrologix PLC. With Delta PLC, you would use ''D'' variablews to send Float, Srtring...
1,786
Hello, I want to connect a Delta DOP-107BV to a Micrologix 1400. Would a DOP-FX cable do the trick?? https://www.ebay.com/c/849453778 I dont think...
2,678
I currently have a Maple Systems HMI (HMI5070P) communicating over Serial DF1 to a MicroLogix 1400. The problem I have is that the HMI will not...
2,097
i want to communicate micrologix 1400 plc to mitsubishi gs2107 hmi. what configuration shoud i do ?
1,068
