Micrologix 1400 Modbus RTU RS485
Raul_Robins
Sep 2013
mexico
Hi everyone,
Im new using modbus and i have some toubles im trying to communicate a micrologix 1400 and a device Satec pm130 via modbus and using the 1763-NC01 cable but it doesn´t works. Can anybody help me Please.
the satec terminals only have rs485+ , rs485- and Shield.
and de 1763-NC01 Term, A, B, Com, Shld, cgnd.
  • Rail_Welding_Machine.zip
I’m pretty sure A and B are the ones used when the port is configured for RS485. Keep in mind that you need to configure the channel 0 port to be RS485 (it defaults to RS232). You may also need to swap A and B around.
As Firejo said...
See picture. Set channel 0's "Protocol Control" to "No Handshaking (485 network)
Hi Mickey ,
I Set channel 0's "Protocol Control" to "No Handshaking (485 network) as you say and works!!! thanks I will continue testing and told them the results.
Thanks a Lot!!
I want to learn about modbus communication and I saw on another thread about inexpensive modbus relay units so I found it on Amazon along with a...
46
7,264
I have a spare Micrologix 1400 Series B I bought used on Ebay awhile back. I had thought of it as a spare PLC for my train project but I screwed...
1,270
Good Day! Would anyone be able to explain what is happening with the COP's and MOV's in this Modbus poll routine? If anything I am confused by...
1,738
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,538
Hi, I am trying to communicate between a MicroLogix 1400 and a Click PLC. There is a great video from AD that shows the simplicity of...
1,786
