Micrologix 1400 Modbus to Quantum PLC
eluder
Oct 2006
Alberta
I am having issues getting a Micrologix 1400 to grab a tag from a quantum PLC.
I have the message instruction setup correctly I believe but I keep getting errors saying no response from network or something like that.
Has anyone sucessfully got this working with a quantum PLC.
Set up is Modbus TCP/IP and I can ping the IP address with no issues that i want to talk to, just not getting responses from the Quantum PLC.
Test the addressing first with a tool like ModScan32, then try the MicroLogix 1400 MSG instruction again.
The trickiest setting I've found with the MSG instruction is making sure you get the Unit ID right. A Quantum should respond to Unit ID=1 because it's a proper Modbus device but I've seen all sorts of variations on this with non-Modicon stuff.
What OS is your quantum running? If it's a Unity based processor then you'll need to have State RAM addressing enabled for this to work. have a look in the Unity Help file on how to do this, it's pretty simple to allocate registers and then assign addresses to your tags.
Unfortunately my Quantums are still running whatever they stuck in them back in '98, with some dodgy 3rd party programmer that likes crashing mid-way through online edits!
I want to learn about modbus communication and I saw on another thread about inexpensive modbus relay units so I found it on Amazon along with a...
46
7,262
I have a spare Micrologix 1400 Series B I bought used on Ebay awhile back. I had thought of it as a spare PLC for my train project but I screwed...
1,266
Good Day! Would anyone be able to explain what is happening with the COP's and MOV's in this Modbus poll routine? If anything I am confused by...
1,738
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,534
Hi, I am trying to communicate between a MicroLogix 1400 and a Click PLC. There is a great video from AD that shows the simplicity of...
1,782
