Micrologix 1400 Power LED/Fault LED Flashing
Amity3467
Feb 2016
Chicago
Good Morning Friends-
I have a Allen Bradley Micrologix 1400
1766-L32BWAA
I was using it for some bench programming and it was most recently on a shelf for 6 months.
When I attempted to re set it up I now get Both a Flashing Power LED and Fault LED with no screen interaction.
My output DC voltage is a steady 23V
I am running out of ideas to try.
Thank You For Any Input
Michael
Hi and Welcome to the Forum!
Your Catalog Number denotes an AC voltage supplied controller...
1766-L32BWAA
Amity3467 said:
...My output DC voltage is a steady 23V...
Are you supplying it with DC voltage?
Regards,
george
No it has 120V AC supply.
I read another post talking about being able to tell if the power supply was cycling based on the DC output.
Thank for the reply.
I've found this in relation to what I mentioned...
567396 - MicroLogix 1400 Power and Fault LEDs Blinking
Access Level: TechConnect
I'm not pushing the above here. You do not have the wrong voltage applied - understood.
I'm just adding it for future reference, lest someone else stumbles upon this thread and actually does have the wrong voltage applied.
Still, the wrong voltage issue presents the very symptoms you describe...
Flashing Power and Fault LED an no LCD display.
All that aside...
The fact that the Power LED is flashing means there is something wrong with either the supply voltage, which you have ruled out, or the power supply itself in the controller. Yet it is converting to 24VDC at the DC OUT terminals?
I'm not usually quick to classify a controller as a "brick", but I just don't know what else could be wrong here other than it's gone faulty?
Is it just the base controller powered up? No expansion I/O modules added?
And no communications cables attached to any of the ports?
Regards,
George
Yep I removed all the expansion and the only wiring connected now is the 120 VAC.
Poor thing barely saw any use at all.
I was in need of a new paper weight.
Thank You for all the helpful information.
Have a great day.
Well don't just take my advice on it. Hopefully someone else might be along with further advice from their experiences. If I think of or find anything else I'll also get back to you.
Have a greater day.
G.
Howdy Everyone, I am doing a project with micrologix 1400 1762-L32BWA, where we talk thru message bits one direction and talk thru the discrete...
418
I'm very new to PLCs and have just acquired a MicroLogix 1400 1766-L32BWA. I can see on the output terminal block two terminals (first two on the...
3,658
How to program addressing in msg instruction for multiple powerflex525 drives micrologix1400 ?
1,263
I have a micrologix 1400 Cat. 1766-L32BXBA Ser. A Rev. C that currently won't power up. When power is applied the power and fault LEDs come on and...
3,612
34
