Micrologix 1500 and production display?
asteroide
Jul 2010
der
158
Hello friends
I need to write and read to a production display, through serial port.
I need to send 2 bytes (1833) and I will receive 32 bytes of data. This should be done at least every 5 seconds.
What instructions do you recommend?
How should I do these?
Any comments would be appreciated
Best regards
In RSLogix 500, look at the "ASCII Control" and "ASCII String" tabs in the "Tabbed Instruction Bar". There you will find the list of instructions that you would be using.
89
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
921
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,431
