Micrologix 1500 erorr code 81
mmgch
Feb 2007
new york
Hi guys,
Did anyone come across this problem?
1764 Micrologix 1500 LRP series c
1769-IT6 6 channel thermocouple
intermittent problem. Every second day the machine went into fault mode when powering up; error 81. I disconnected module and reconnected it. I checked the connection and it seems good. If I switch the switch to run mode, fault goes away. now I'm getting the fault every couple of hours.
Did anyone have that experience what the fault might be before I start changing parts?
This board is a great source of information for me. Id like to thank all the participants for your knowledge and help.
See picture below.
Check and double check grounding. If you are switching inductive loads (e.g. solenoids), do they have surge protection?
97
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
108
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
923
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,434
