micrologix 1500 hardware fault
metricelec
Oct 2006
east coast
Hello,
I have a new micrologix 1500 processor LSP rev. D ser. C
in a base unit 1764-24BWA Ser. B Rev. A This combination is
giving me a hardware fault when I try to go to run mode?
I have had this processor running in an other base unit with
no problems before can you help me? Fault on Value on S:6 is 8h
Thanks,
whats in the error description? did u try clear major error?
8h is internal software error...may be u should post the program here so that someone can look at it.
Yes I reset the fault and every time I try to go to run it returns,
the fault is base hardware fault ot is incompatable with the OS
Recommended action from AB is to replace the base unit.
what is the Hardware series revision of the Base & processor unit & what is the firmware revision of the Processor unit
metricelec said:
The base unit is 1764-24BWA Ser.B Rev.A the processor is 1764-LSP Ser.C REv.D FRN 9
I guess you have replace the base unit with Ser C, or otherwise change processor unit to Ser.B
actually purchased a new base -------- series and rev # the same as the old one and it works fine
AB distributer tells me that any processor will work with any base. I am sending old base out for repair to see what is wrong with it. All is good now !
I have recently started to work with an OEM in Thailand making packaging machinery. I was just informed that they have sold 12 machines to a...
4,618
123
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
122
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
933
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,216
