Micrologix 1500 OF-2
olias
Apr 2002
North Jersey
185
Easy one for you guys.This is my first time with analog.
How do I configure the output module for 4-20ma. And then, how do I convert RPMs to 4-20ma? "Help" doesn't.
Thanks in advance.
Click on the IO Configuration in the project listing on the left side of the RSLogix screen, highlight the output card, and then click on advanced. From there on it is fairly straightforward to configure the card.
To convert the rpm data to the card 4-20 mA output use the SCP function.
Thanks. Set up the card, but didn't understand how the card would know what I wanted. Didn't know about the SCP function.
Olias
100
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
112
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
924
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,212
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,434
