Micrologix 1500 relay bad?
garfields
Oct 2010
usa
One of the relays in a micrologix 1500 has welded shut. It's controling a 24 volt motor starter coil. Can these be serviced? It's in an automatic carwash and if I have to replace the whole unit can I copy the logic to another 1500 so I don't have to go to the oem?
Yes
If you have the software to upload the program. Or if it has a memory module.
I don't know if it can be serviced or not, hopefully someone that does know will jump in.
Edit:
To add to tarik1978's comments surge protection and I always use slave relays for this kind of application. Much easier to change the slave relay.
If you have one spare relay available you can use it but you have to change the program.
Also it's good practice to put a free wheel diode across the coil to extend the life of the relay.
Good luck
If the OEM has protected it will I be able to change the program ?
Depends on how the OEM protected it. Password? ( can you get it?)
OEM lock , you will need the OEM.
Do you have a backup of the program? If so, can you open it with RSLogix500?
99
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
111
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
923
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,434
