Micrologix 1500 sequencers and timers
Programmer4
May 2009
Tennessee
29
I was wondering how I might go about using my sequencer in such a way that I can set a time at each step or positon in the sequence. What will be the easiest way to do this?
ex:
step 1=2sec
step 2=6sec
step 3=7sec
etc...
...the sequencer step bit enables the timer...the timer DN bit steps the sequencer...
BTW, my sequencers these days are almost always an "add 1 to a register (N7:0, say) when the step is true" type and the decoded step bits are generated by an unconditional coil with the address B3:0.[N7:0] just include a fle fill function immediately before the coil to clear the unaddressed bits. A very simple sequencer. For multiple times, load just one timer indirectly using the current step number to pick a time from an array.
91
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
922
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,433
