Micrologix 1500 - Splitting a network feed?
donl517
Dec 2005
Michigan
127
I have a customer who wants to take a network cable plugged into a barcode printer, split the signal and send it to a Micrologix 1500 at the same time as the printer. Any thoughts?
Thanks,
Don
when you say network cable you mean Cat-5?
If it is you have to goto the source and get it to send it to your Micrologix with OPC or someother kind of service. But if its Ascii through Serial you can "tap" off of it and get the signal that way. But dont try to take it too far as the signal will degrade.
Chris,
Thanks for the reply. Yes it is a Cat-5 cable. I was hoping it would be easier than that. It is in the middle of the plant a long way from the source PC.
Don
126
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
123
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
937
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,220
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,442
