Micrologix 1500 STI file
Your post ended up in the "practice" section, so be sure future ones go into the main Forum.
The only important difference between the STI routine and any other subroutine is the interrupt mechanism. The same main routine watchdog applies (100 ms default) to a program using an STI as to one without it.
You can load up the STI subroutine with PID equations as much as the controller memory will take. There is no predefined limit on PIDs that any A-B controller will run.
99
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
112
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
923
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,434
